soma.india08 Tue, 05/13/2008 - 07:24
hii,
thanks for reply. those are the very good document. but I didn't get any information about that How to generate the miss called in CDR Report . please sent me the procedure for missed call configuration in CDR,
Thanks & Regards
Soma
Jaime Valencia Tue, 05/13/2008 - 09:29
  • Cisco Employee,
  • Hall of Fame,
    2011
missed calls should show up as 0 duration if you have that parameter enabled, since they were never connected they should show up that way
javalenc
if this helps, please rate
soma.india08 Wed, 05/14/2008 - 01:43
Dear,
Thanks for reply.that means u telling about
'CDR Log calls with zero duration flag' should be enable? I already enabled this parameter , but still now its not generated any zero duration calls in CDR Report.
So plz suggest me.
thanks & regards
Soma
Amien7049 Tue, 12/23/2008 - 12:58
hi
is this allready solved .. can you perhaps share the solution .. thanks in advanced
