AXL Serviceability code not working on CM6.0, Please Help
May 7th, 2008
I am trying to run the AXL Serviceability code against my CM6.0.
But unfortunately, when executed, i get an error which asks me to check the XML document structure.
When viewed the xml request code snippet in an xml editor, its all fine...all the open tags have the corresponding closing tags.
I did try with various xml messages; the output is always the same.
Please help me in this regards.
Shank
Request Header:
POST /realtimeservice/services/RisPort HTTP/1.1
Content-Type: text/xml; charset=utf-8
SOAPAction: "http://schemas.cisco.com/ast/soap/action/#RisPort#SelectCmDevice"
Authorization: Basic xxxxxxxxxxxxxxxxxxxxx
Host: x.x.x.x
Content-Length: 240
Soap Message:
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:tns="http://schemas.cisco.com/ast/soap/" xmlns:types="http://schemas.cisco.com/ast/soap/encodedTypes" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Header>
<tns:AstHeader id="id1">
<SessionId xsi:type="xsd:string">2006-02-01T07:16:21</SessionId>
</tns:AstHeader>
</soap:Header>
<soap:Body soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<tns:SelectCmDevice>
<CmSelectionCriteria href="#id1"/>
</tns:SelectCmDevice>
<tns:CmSelectionCriteria id="id1" xsi:type="tns:CmSelectionCriteria">
<MaxReturnedDevices xsi:type="xsd:unsignedInt">4294967295</MaxReturnedDevices>
<Class xsi:type="tns:DeviceClass">Phone</Class>
<Model xsi:type="xsd:unsignedInt">0</Model>
<Status xsi:type="tns:CmDevRegStat">Any</Status>
<SelectBy xsi:type="tns:CmSelectBy">Name</SelectBy>
<SelectItems href="#id2"/>
</tns:CmSelectionCriteria>
<soapenc:Array id="id2" soapenc:arrayType="tns:SelectItem[1]">
<Item href="#id3"/>
</soapenc:Array>
<tns:SelectItem id="id3" xsi:type="tns:SelectItem">
<Item xsi:type="xsd:string">SEP0017E00CCC11</Item>
</tns:SelectItem>
</soap:Body>
</soap:Envelope>
Response:
HTTP/1.1 500 Internal Server Error
Server: Apache-Coyote/1.1
Set-Cookie: JSESSIONIDSSO=95D6DB9B11D5BBEA9A74F5E72D34D3A0; Path=/
Set-Cookie: JSESSIONID=921AACE45DDADBE70DD99DD6C432D633; Path=/realtimeservice; Secure
Set-Cookie: SoapSession.id=1742396451575972205
Content-Type: text/xml;charset=utf-8
Transfer-Encoding: chunked
Date: Tue, 06 May 2008 16:13:25 GMT
Connection: close
23f
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
<soapenv:Fault>
<faultcode>soapenv:Server.userException</faultcode>
<faultstring>org.xml.sax.SAXParseException: XML document structures must start and end within the same entity.</faultstring>
<detail><ns1:hostname xmlns:ns1="http://xml.apache.org/axis/">test.myhome.com</ns1:hostname>
</detail>
</soapenv:Fault>
</soapenv:Body>
</soapenv:Envelope>
agiaccone Wed, 05/07/2008 - 06:31
  • Bronze, 100 points or more
try removing <?xml version="1.0" encoding="utf-8"?> at the beginning of the request body.
HTH,
Alberto
stephan.steiner Thu, 05/08/2008 - 08:00
  • Silver, 250 points or more
You might wanna search for the thread where I asked for a SelctCmDevices example.. then use that as a starting point. That's how I finally managed to get things working on my CCM 5.1 and 6.1.
