e.huntley Tue, 05/13/2008 - 11:47
Let me tell you from experience you need more like 5 or 6 GB. Even if you start with 4GB free, it does that pre-extraction. So then it extracts the executable, which puts you back under 4 GB and then fails.
So then you get past that point, it does the extraction, then starts running the setup puts you back under 4GB and fails again.
So what it really means is during the entire process of the install, you must always have more than 4 GB.
