How to define the access list on router?
guruprasadr Wed, 05/07/2008 - 00:42
  • Gold, 750 points or more
HI, [Pls Rate if HELPS]
Create and Extended ACL as below:
Extended IP access list allow
10 permit ip host 192.168.23.1 any
20 permit ip host 192.168.23.4 any
30 permit ip host 192.168.23.8 any
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
guruprasadr Wed, 05/07/2008 - 01:13
Explicit deny will be available by default as the last statement. When you match the ACL, the 3" ip address will only be allowed and rest all be denied using explicit deny available by default.
Hope I am informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Hi There
Not exactly. The number "30" at the start of the ACL defines the line number of the ACL that this statement will occupy and in your example you are attempting to put three statements on the one line. This will not be permitted.
However you could use
ip access-list extended 100
permit tcp host 192.168.23.1 0.0.0.255 any eq 12322
permit tcp host 192.168.23.1 0.0.0.255 any eq 13432
permit tcp host 192.168.23.1 0.0.0.255 any eq 12324
permit tcp host 192.168.23.4 0.0.0.255 any eq 12322
permit tcp host 192.168.23.4 0.0.0.255 any eq 13432
permit tcp host 192.168.23.4 0.0.0.255 any eq 12324
permit tcp host 192.168.23.8 0.0.0.255 any eq 12322
permit tcp host 192.168.23.8 0.0.0.255 any eq 13432
permit tcp host 192.168.23.8 0.0.0.255 any eq 12324
Best Regards,
Michael
Hi Again
Actually there is an error in the ACL statements I have shown.
If you only want these statements to apply to the specific host addresses shown, leave out the wildcard mask (0.0.0.255) from all statements.
If you want these statements to apply to the entire subnets, then leave out the keyword "host" from all statements.
Best Regards,
Michael
Hi There
If you want to block/permit EVERY port between say 1500 and 1900 then you could use the "range" option
i.e. permit tcp host 192.168.23.8 0.0.0.255 any range 1500 1900
However if you only want to block/permit say port 1500, 1675, 1806 & 1897, then you would need to write a single line for each individual port that you wish to cover.
Best Regards,
Michael
