FXO issue with CME and AA script
May 7th, 2008
Hi all recently i have configured for a customer CCME , AA and FXO card but some times the FXO card start "dumming" i mean when you call the customer from outside you will be redirected to the AA and when you hand up it's fine the disconnect supervisory works fine but sometimes from the outside you will hear a message from the service prvider stating that the line is no longer available and from the inside when you try to use the outside line you hear a busy signal
So my configuration is as follow:
voice class custom-cptone Discon
dualtone disconnect
frequency 425
cadence 500 500
voice-port 0/0/0
trunk-group Amira 1
supervisory disconnect dualtone mid-call
supervisory custom-cptone Discon
timeouts call-disconnect 1
timeouts wait-release 1
dial-peer voice 5 pots
service main-aa
port 0/3/0
dial-peer voice 1 pots
trunkgroup Amira
destination-pattern 9T
So can anyone please help me :) i'm really stuck!!!!
Razeen Abdulla Fri, 11/07/2014 - 00:44
Did u get a solution? facing same problem now. really appreciate your help. :)
