Time in CDR's
Answered Question
May 7th, 2008
When you export CDR's to a server in order to manage it, the time that appears is the "current time" of the CallManager (UTC time). I'd like it appears the "local time" of the CallManager. Is it possible? What do I have to configure? Thanks,
Correct Answer by Jaime Valencia about 8 years 10 months ago
no it's not possible, all those records have UTC time and you cannot change that, you need to do the conversion
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 05/07/2008 - 06:32
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
