Joe Clarke Wed, 05/07/2008 - 09:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Exactly what version of Campus Manager is this?
orsonjoon Thu, 05/08/2008 - 23:54
Thanks for your reply, the versions we are using:
CiscoWorks Common Services 3.1.1
Campus Manager 5.0.2
CiscoView 6.1.7
CiscoWorks Assistant 1.0.1
Device Fault Manager 3.0.2
Internetwork Performance Monitor 4.0.1
Integration Utility 1.7.1
LMS Portal 1.0.1
Resource Manager Essentials 4.1.1
Joe Clarke Fri, 05/09/2008 - 09:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I think you may have found a bug. Try running a new Campus Data Collection, then see if the manual devices interface works again.
orsonjoon Mon, 05/12/2008 - 22:08
No, unfortunately the same problem occurs. I will report this at TAC and make a case here.
Thanks for your support!
