paolo bevilacqua Wed, 05/07/2008 - 03:35
  • Hall of Fame,
    Founding Member
Do not use ethernet cable. Please use only proper T1 cable, 100 Ohm impedence, with the correct pinout ans pair twisting, as per manual.
Rob Huffman Wed, 05/07/2008 - 04:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jerry,
Hope all is well :) Just wanted to add a note to the good info from my friend Paolo. This doc has some good references for the RJ48 Pinouts;
http://www.cisco.com/en/US/docs/routers/access/hardware/notes/marcabl.html#wp38057
Hope this helps!
Rob
Zin.Karzazi Wed, 05/07/2008 - 04:26
  • Silver, 250 points or more
We use RJ45 for our PRIs without any Problems. If you just need a short Cable to connect to your E1, RJ45 would be fine.
rich_harris Wed, 05/07/2008 - 05:19
Sometimes the telco terminating box will only accept the keyed RJ48C but in most cases we use RJ45 straight through with no problems.
paolo bevilacqua Wed, 05/07/2008 - 05:55
  • Hall of Fame,
    Founding Member
Rj48C twisting is different from ethernet, hence no protection from interference, and bigger radiated interfences.
All is good until strange eproblems happens, at that time you will replace the cable anyway, so why don't do things rights since the beginning.
rich_harris Thu, 05/08/2008 - 01:12
Agreed, I'm all for doing things properly and if the telco kit does have the proper keyed socket you are safe.
Rich
