05-07-2008 03:37 AM - edited 03-15-2019 10:30 AM
I am trying to connect an Ericsson MD110 with an IPLU card via H323 to CUCM 6.1 without much success.
Has anyone attempted this sort of config before? All of the integration notes have TDM connections on the Ericsson end.
Andrew
05-07-2008 09:06 PM
Try different options:
1. Configure H323 GW in CCM
a.Try MTP only using G711
b Try Fast start (Outbound Inbound)
c Enable Wait for far end H245 caps
d. Check codecs
2. Configure it as ICT
05-07-2008 09:09 PM
Thanks for the response.
I have tried a,b,c,d and calls from the Cisco to Ericsson ring, connect and then drop after ~10 seconds. Incoming calls from the Ericsson to the Cisco ring but don't connect.
I'll try an ICT.
