05-07-2008 03:37 AM - edited 03-13-2019 05:13 PM
Users forgots thers ids to access to mailbox, I need the default ID and if it exist id recovery to force a specific id
Thanks.
05-07-2008 02:17 PM
exactly what do you mean by their id??
if my DN is 7777 then that's my id (unless you have VM box mask under the vm profile)
also you do not mention what you're using, Unity? CUC? CUE?
javalenc
if this helps, please rate
05-08-2008 12:40 AM
I'am using UC520
the id is the code wich we must enter when trying to read messages from mailbox.
Thanks.
