Can someone check this Cisco document for me.. is it what i need :)
Answered Question
May 7th, 2008
Hi all. Take a look at this:
http://www.cisco.com/en/US/docs/voice_ip_comm/sbcs/hardware/quick/guide/uc5_tele.html
Now basically i need to set up a network for a new customer, and its going to be exactly like that, but with a 2801 instead of a UC520.
At head office ill have a 2801, that will be connected to a DSL router.
At the remote site ill have an 877, and im hoping to make a VPN tunnel through and terminate it on the 2801. Is this possible?
Also another question I have, I need to install an SBS server at head office too. This will need to be visible on the Internet because it'll have exchange on it. Can I set the router to pass all traffic through to the 2801, then let the 2801 send traffic off to the SBS server?
Correct Answer by paolo bevilacqua about 8 years 11 months ago
Sure, you can do these things.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Wed, 05/07/2008 - 05:56
  • Hall of Fame,
    Founding Member
davieshuw Wed, 05/07/2008 - 06:23
yes just wanted someone to check it over make sure I wasnt doing anything odd
Thanks mate :)
paolo bevilacqua Wed, 05/07/2008 - 14:08
  • Hall of Fame,
    Founding Member
No problem, thanks for the nice rating and good luck!
