switchport trunk vlan allowed not workink
dragec
I have trunk port between two swithes, bot are in same vtp domain, and I cannot put switchport trunk allowed vlan command on port. After commande there is no this command in config, and when I look at port with sh int x/x trunk, also nothing changed
don't add the vlan, allow it only if it is the 1st one and only one on the trunk. after that u can use the "add "
Switch(config-if)#switchport trunk allowed vlan 99
Sam
7 Replies 7
cisco_lad2004
Level 5
Level 5
not knowing which platform or release, hard to tell if there is a know issue.
anyways, is port configured as switchport and trunk encapsulation set ?
Sam
3560, ipbase 12.25. Ports are configured as trunks and enc is set and ports are trunking fine
Normally this works. Could you show us an example please? For example, a terminal session with:
- the show run int before the change,
- the command to do the change,
- the show run int after the change.
Kevin Dorrell
Luxembourg
here it is
sh runn int g0/1
Building configuration...
Current configuration : 231 bytes
interface GigabitEthernet0/1
switchport mode trunk
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust cos
auto qos voip trust
end
#conf te
Enter configuration commands, one per line. End with CNTL/Z.
(config)#int g0/1
(config-if)#switch trunk all
(config-if)#switch trunk allowed vlan add 99
(config-if)#end
#conf tesh runn int g0/1
queue-set 2
mls qos trust cos
auto qos voip trust
end
Sam
:-))), thanks
below on 3560 / C3560-ADVIPSERVICESK
Switch(config-if)#switchport trunk allowed vlan 210
Switch#sh run
interface FastEthernet0/2
