WLC DHCP question
May 7th, 2008
Hi all
Is it possible to issue a static IP address to a user using the WLC's built-in DHCP server? Each time I connect to a different WLAN and then reconnect to the WLC WLAN, I get a different IP address, even though I've reconnected before the lease time for the IP is set to expire.
Our code version is 4.0.217.0, and the WLC is installed into a 2811.
