Customizing CDR reports from CUCM
May 7th, 2008
Hi all,
A client has sent the following request pertaining to a new deployment. I can show them how to pull CDR records and some of the built in reports but is there a product out there which will them to create customized reports directly from the CDR/CAR databases? Thanks in advance for any assistnace.
"For some time now I have been trying to get a CDR record out of the system. The record needs to include Extension, Name, Time, Duration, Digits dialled, and when multiple records are found they should be grouped by Extension."
gogasca Wed, 05/07/2008 - 20:58
  • Green, 3000 points or more
No option inside CDR
They need to go for a 3rd party billing server
which provide those options
walidazab Sun, 05/25/2008 - 08:03
I know of a product that can do that for you. You can contact me for more details.
Reagards..
jking2685 Wed, 11/02/2011 - 02:22
You should use a 3rd party call logging product for this.
Certified products can be found on the Cisco Developer site http://developer.cisco.com/web/partner/search?text=call logging&technologyIds=a0G40000000xlnlEAA&certified=Yes&onCiscoPriceList=All&portfolioPartner=All
Depending on your UCM size we have two products that auto configure, based on your UCM configuration to load all your users, handsets, gateways, UDP's etc. Installs are less than five minutes!
TIM Plus for up to 400 users and TIM Enterprise which has unlimited users, both have AXL integration and free unlimited display boards, unlimited web users. For more information or to arrange a free trial go to www.tri-line.com/cisco
TIM Enterprise overview video:
AXL integration video:
Let me know if you need any further information.
