CCME - Ability to browse voicemail on phone?
Answered Question
May 7th, 2008
I've just read a paraagraph in some ciso documentation that reads:
• Ability to view, sort, search, and play back voice messages using the display of a Cisco Unified IP Phone or your e-mail client
I know how the email client works, but how would I 'browse' my voicemail on, for example, a 7941 or 7931? (Thats running over a UC520)
Correct Answer by dezoconnor about 8 years 10 months ago
The feature you're referring to is called Voiceview express and is available to CCME and CUE users.
Voice View Express allows users to browse, listen, send messages, and manage their voice mail messages from their Cisco IP phone display and soft keys. Instead of dialing into the telephone user interface, you can use the screen of your phone to select which messages (and in which order) you want to listen to.
I'm not sure if this feature is available for the UC500 product range.
Overall Rating: 5 (5 ratings)
Correct Answer
dezoconnor Wed, 05/07/2008 - 07:37
  • Silver, 250 points or more
Rob Huffman Wed, 05/07/2008 - 07:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Huw,
Just to add a note to the good info from Dez (5 points for your good work Dez!)
Overview of VoiceView Express
The VoiceView Express feature allows voice-mail subscribers to browse, listen, send messages, and manage their voice mail messages from their Cisco IP phone display and soft keys. This feature is an alternative to the telephone user interface (TUI) for performing common tasks.
VoiceView Express is available on the Cisco advanced integration module (AIM) and on the network modules NM-CUE and NM-CUE-EC.
VoiceView Express is available for Cisco Unified Communications Manager Express and Cisco Unified Communications Manager systems. VoiceView is not available in Cisco Unified Communications Manager SRST mode.
Only Cisco IP phones 7940, 7941, 7960, 7961, 7970, and 7971 support VoiceView Express.
VoiceView Express is enabled by default.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/administration/guide/voicemail/7vview.html
Q. Does the Cisco Unified Communications 500 Series support e-mail integration and
Cisco Unity Express VoiceView Express?
A. Yes, the Cisco Unified Communications 500 Series supports Internet Mail Access Protocol
(IMAP) integration and VoiceView Express the same way as a network module of Cisco Unity
Express on Cisco Unified Communications Manager Express.
http://www.cisco.com/en/US/solutions/ns339/ns637/networking_solutions_products_genericcontent0900aecd806122df.pdf
Hope this helps!
Rob
dezoconnor Wed, 05/07/2008 - 07:43
What can I say but thanks Rob! I've learnt that the UC 500 series do support voiceview thanks to you.
Cheers.
Darren
Rob Huffman Wed, 05/07/2008 - 07:47
  • Hall of Fame,
    Founding Member
Hi Darren,
My Bad!
My sincere apologies for getting your name wrong :( I feel like an A#!
I have read many of your good posts and always thought;
Good one Dez!
I will not make this mistake again, I promise :)
Take care and thanks!
Rob
dezoconnor Wed, 05/07/2008 - 07:52
LOL :-)
Sorry Rob, my nickname is dezoconnor but my christian name is Darren. Sorry for the confusion.
davieshuw Wed, 05/07/2008 - 07:49
Thank you indeed gentlemen! Well you learn a new thing every day here dont you
Cheers :)
Rob Huffman Wed, 05/07/2008 - 09:15
  • Hall of Fame,
    Founding Member
Hi Huw,
You are most welcome! Hope I didn't get your name wrong as well :)
Take care,
Rob
