Multicast high cpu
May 7th, 2008
My cisco 4506 goes nuts every time i turn multicast on. Unfortunately most of my inherited network is on vlan 1, which i'm slowly segmenting. When ever we need to use a multicast application i have to turn multicast on for vlan 1 (ip pim sparse-mode) When i enable it my cpu stays around 80-100%. When i run a show ip mroute counters there are about 50 routes in it. I guess my question is what can i do about this. I'm sure there are a few different applications that use it but there are all kinds of MC IP's. If i ping one of the IP's, it replays back from a network printer, a proximity panel. is this even reliable?
cisco_lad2004 Wed, 05/07/2008 - 13:34
  • Gold, 750 points or more
Make sure you do not have igmp static join on any loopbacks.
I had few cases were it caused 60% CPU increase as packers were process switched.
Sam
cowetacoit Thu, 05/08/2008 - 07:38
It isn't. Someone on another forum said to enable IGMP Snooping. i did, and the CPU didn't drop.
cisco_lad2004 Thu, 05/08/2008 - 10:49
can u identify any interfaces that are switching a heavy load ?
what does "sh process cpu | exc 0.00" list.
with 4500 you can actually SPAN CPU and find out what is hitting it.
Sam
