Simple IP Phone Service Issue
May 7th, 2008
I am developing an IP Phone Service. I am creating a IPPhoneTextObject and have added several soft keys. This works fine, however, on the phone (7945), If I push one of the soft key buttons, the phone displays: "That Key Is Not Active Here"
Anyone have any ideas? I sincerely appreciate your time.
Michael
Overall Rating: 5 (1 ratings)
agiaccone Wed, 05/07/2008 - 09:02
the notation is case sensitive, and the position is always the same in your code.
So replace all of the occurrences with (and obviously), and change the position valu to 1 to 4 instead of always 1 for all of the softkeys.
This way should work.
HTH,
Alberto
developer_mike_smith Wed, 05/07/2008 - 09:24
Thank you so much for the reply. I greatly appreciate it. That was a typographical error on my behalf. Here's the current XML that is generated & I still recieve the same error.
IP Phone Service
Button Configuration...
Developed By M. Smith
Button1
http://10.1.0.75/Page2.aspx
Button2
http://10.1.0.75/Page3.aspx
Button3
http://10.1.0.75/Page4.aspx
Button4
http://10.1.0.75/Page5.aspx
developer_mike_smith Wed, 05/07/2008 - 09:26
Outstanding! It was the fact that the 'Url' was not capitalized. I am greatfull for your help.
Cheers,
Michael
agiaccone Thu, 05/08/2008 - 06:46
In the lower right part of the post you'd like to rate there's a dropdown list and a button.
From the dropdown select the vote, then click submit.
bye,
Alberto
