05-07-2008 07:37 AM - edited 07-03-2021 03:49 PM
I have 1 2106 wlc 6 1131AG LAPs that are going to be placed in three vlans. All three vlans are created and configured on a 3550G switch.
I created two additional virtual interfaces on the WLC, tagged it with appropriate vlan number and connected the port with untagged vlan identifier to a dot1q enabled trunk port on the 3550 switch. That is,
man int - untagged, port 1
vlan2, tagged -2, port 2,3
vlan3, tagged -3, port 4,5
vlan4, tagged - 3, port 6
and port 1 is connected to a trunk port on the 3550G switch with dot1q.
I am not able to reach the created vlan interfaces on the WLC !?1?!
Kindly help?
05-07-2008 08:38 AM
AFAIK, the dynamic interfaces have to be physically connected, the WLC doesn't act as a switch in that fashion. So you either need to plug in ports 2-6 to the 3550, or re-assign the dynamic interfaces for the VLANs to port 1.
05-07-2008 08:56 AM
jeff.velten, wouldn't that break the very use of the WLC? documents I referred from cisco recommend to connect the WLC to a trunked port. Like here: http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805e7a24.shtml
So how are the vlan tags from the wlc not passed on to the trunk port? Is there something I missed, somewhere?
