VPN client connection
Answered Question
May 7th, 2008
Is there a way to configure the VPN client to configure some way the login and password so when you execute it, automatically connects without writing login and password.
These has to be on vpn client without making any changes on vpn server.
Any idea how to do this?
Correct Answer by andrew.prince@m... about 9 years 2 months ago
in vers 4.0.2, 4.6 & 4.8 Yes - in the .pcf profile file, make sure
SaveUserPassword=1
This will keep the username & password in the profile, when you click it - it should login fine.
You also need to enable the store user password:-
In the pix/asa - under the client VPN profile:-
password-storage enable
HTH.
Overall Rating: 5 (1 ratings)
Correct Answer
andrew.prince@m... Wed, 05/07/2008 - 11:28
  • Green, 3000 points or more
SaveUserPassword=1
HTH.
