6513 multiple dhcp-pool domain-names
May 7th, 2008
Is it possible to add multiple domain-names in dhcp-pool config on the 6513?
In other words is this a legitimate command : domain-name abc.net,xyzoa.net,xyz.co.jp? Or is there some other way to make it work?
Thanks.
vpersaud001 Fri, 05/09/2008 - 08:48
Noran... Thanks.
I need to know if you can set multiple domain search suffix for each DHCP pool.
Unless I missed it the document only shows one dhcpd domain - example.com. I actually tried to add another domain but it replaced the previous one.
Iain Fri, 05/09/2008 - 21:48
Let me know if you figure this out. I'm trying to do the same thing.
- Iain
I have been toying with this in my lab to no avail. After further research i found this:
http://www.iana.org/assignments/bootp-dhcp-parameters
It makes mention of option '135' which MS recognizes as domain suffix search-order, but that doesn't mean anything. I tried a couple different variations under my test dhcp pool...
option 135 ascii "\"test1.com\",\"test.com\""
option 135 ascii "test1.com,test.com"
but none of these ever get served to my client (according to wireshark). I would lean towards this being an issue with the IOS not serving statically configured options.
vpersaud001 Tue, 05/13/2008 - 05:10
Lain,
Per advice from another forum this can only be accomplished in a Windows environment via group policy.
