Richard Burts Wed, 05/07/2008 - 10:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Tate
Perhaps I am not understanding something in your question. I have been doing IPSec VPN to protect GRE tunnels on 1721 routers since very early 12.3 mainline code. Or perhaps you are referring to tunnel protection used with the Virtual Tunnel Interface which I find supported on 1721 since 12.3(14)T.
If I am not understanding what you are asking then please clarify.
Rick
luthierone Wed, 05/07/2008 - 10:29
OK, I guess the "tunnel protection ipsec profile profile_name" command is available but it looks like "tunnel mode ipsec" isn't. Maybe you don't need that last command to get the ipsec tunnel to work? I always just resorted to building my crypto maps statically on 1721's because of that.
