6500 as a WAN router - best practice?
Answered Question
May 7th, 2008
We are wanting to move our WAN connections off a 7200 to 6500's. I am trying to determine best practice for configuring of the ports. Right now we have a single 7200 but will be moving to a dual-6509 core. The plan is for most of the connection to go to 6509-A but we will setup a port on the 6509-B that matches in case 6509-A fails we can manually move the connection over.
For the connections that come in as ethernet hand offs what is the best practice to configure the port? Should we do a "no switchport" and just assign the IP to the interface similar to the 7200 config or should we setup a vlan for the WAN connection and then assign that vlan to the switch port?
What else do I need to consider before making this transition?
Correct Answer by Jon Marshall about 8 years 10 months ago
I would configure the ports as L3 ports ie. "no switchport" and assign the IP to the interface. Setting up a vlan for the WAN connections introduces STP where you don't need it.
Apart from routing protocol support and line terminations which i'm assuming you have already checked the only thing i would consider (if you haven't already) is to use a redundant supervisor in the 6500 chassis for added redundancy.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 05/07/2008 - 10:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
sdrossen2 Wed, 05/07/2008 - 10:54
We do have dual Sup720's in the 6500 and are working thought the BGP and EIGRP configs right now.
Jon Marshall Wed, 05/07/2008 - 11:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Then you should be fine.
Good luck.
