Build PhoneMenu object with Database Entries
I am designing an ASP page that uses a library to generate XML phone objects. I want to dynamically create a PhoneMenu object using names retrieved from a database. However, when I open the connection to the database, the XML does not display on the phone.
Any ideas would be greatly appreciated.
Kind Regards,
Michael Smith
5 Replies 5
agiaccone
Paste some code snippet so that we can have a look at the part which doesn't work.
Alberto
Thank you so much for the reply! Here's a snippet of the class I'm using...
Partial Public Class _Default
Inherits System.Web.UI.Page
Dim a As New SqlClient.SqlConnection("Data Source=;Initial Catalog=PhoneTest;Integrated Security=True")
Dim _names As ArrayList
Private Sub Page_Init(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Init
a.Open()
' Note: If the above line is commented out, it works fine on the phone...
End Sub
Private Sub FillArrayList()
Dim DA As New SqlClient.SqlDataAdapter("SELECT * From Employees", a)
Dim DT As New DataTable
DA.Fill(DT)
For Each dr As DataRow In DT.Rows
-Names.Add(dr(1).ToString)
Next
DA.Dispose()
DT.Dispose()
End Sub
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Response.ContentType = "text/xml"
' Testing PhoneText object
'Dim t As Cisco_Handler.CiscoIPPhoneServices.CiscoIPPhoneText = New CiscoIPPhoneText("IP Phone Service", "Button Configuration...", "Developed By M. Smith")
't.AddSoftKey(New Cisco_Handler.CiscoIPPhoneServices.CiscoSoftKey("Button1", "http://10.1.0.75/Page2.aspx", 1))
't.AddSoftKey(New Cisco_Handler.CiscoIPPhoneServices.CiscoSoftKey("Button2", "http://10.1.0.75/Page2.aspx", 2))
't.AddSoftKey(New Cisco_Handler.CiscoIPPhoneServices.CiscoSoftKey("Button3", "http://10.1.0.75/Page3.aspx", 3))
't.AddSoftKey(New Cisco_Handler.CiscoIPPhoneServices.CiscoSoftKey("Button4", "http://10.1.0.75/Page4.aspx", 4))
' Test PhoneInput Object -- Works Fine
'Dim t As New CiscoIPPhoneInput("Title1", "prompt", "http://test.com")
't.AddInput("Display1", Cisco_Handler.InputFlags.A)
' Testing Phone Menu
Dim t As New CiscoIPPhoneMenu("My IP Service Main Menu", "Choose Selection:")
t.AddMenuItem(_names.Item(0).ToString, "http://10.1.0.75/Page2.aspx")
t.AddMenuItem(_names.Item(0).ToString, "http://10.1.0.75/Page3.aspx")
' Send objec to phone..
Response.Write(t.ToString())
End Sub
End Class
I greatly appreciate your help,
Michael
If you try to display the output with internet explorer what do you see ?
If nothing is displayed, maybe your AddMenuItem method could have some error in formatting xml..
If I open the page in IE, it displays the properly formatted XML as it should (including the database entries as buttons) . If I were to comment out the line that reads 'a.open' everything displays correctly on the phone (except for the names being generated from the database; which comes from the following line: t.AddMenuItem(_names.Item(0).ToString, "http://10.1.0.75/Page2.aspx") )
I'm unclear why connecting to a sql server instance prevents the XML from displaying on the phone.
Any insight would be greatly appreciated.
Cheers,
Michael
I have fixed this issue myself. Thanks for the help everyone!
Cheers,
Michael
