Accounting record not sent (Aironet 1131AG)
May 7th, 2008
I have problem with accounting on my Cisco Aironets 1131AG configured into WDS domain. There arent sent any START-STOP radius records. Why???
Cisco Aironet, Software Version 12.4(10b)JA3
---------------- debug msg -------------------
May 7 18:58:34: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0012.f004.1d4e Associated KEY_MGMT[WPAv2]
May 7 16:58:34.111: AAA/ACCT/NET(00000014): Pick method list 'acct_methods'
May 7 16:58:34.112: AAA/ACCT/SETMLIST(00000014): Handle B6000004, mlist 010F5EE8, Name acct_methods
May 7 16:58:34.112: AAA/MLIST Ref count of of mlist 0x10F5EE8 raised to 2
May 7 16:58:34.112: AAA/ACCT(00000014): Type NET: Periodic timer initialized
May 7 16:58:34.112: dot11_aaa_start_accounting: Starting accounting for user: mbe
May 7 16:58:34.112: AAA/ACCT/EVENT/(00000014): NET UP
May 7 16:59:08.995: dot11_aaa_stop_accounting: Stopping accounting for user: 0012.f004.1d4e
May 7 16:59:08.996: AAA/ACCT/EVENT/(00000014): NET DOWN
May 7 16:59:08.996: dot11_aaa_upd_accounting: Updating attributes for user: 0012.f004.1d4e
May 7 16:59:08.997: AAA/ACCT/HC(00000014): DOT11/00C07260 [sess] (rx/tx) base 0/0 pre 496/858 call 1593/1956
May 7 16:59:08.997: AAA/ACCT/HC(00000014): DOT11/00C07260 [sess] (rx/tx) adjusted, pre 496/858 call 1097/1098
May 7 16:59:08.997: AAA/ACCT/NET(00000014): Accounting record not sent
---------------- config snip -------------------
aaa group server radius t-radius
server auth-port 2812 acct-port 2813
aaa group server radius t-radius-acc
aaa authentication login default local
aaa authentication login eap_methods group t-radius
aaa authentication login WLCCP group t-radius
aaa authorization network WLCCP group t-radius
aaa accounting delay-start
aaa accounting update periodic 5
aaa accounting network acct_methods start-stop group t-radius-acc
aaa accounting connection acct_methods start-stop group t-radius-acc
dot11 ssid bigspace
vlan 67
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
accounting acct_methods
mbssid guest-mode
wlccp ap username AP1 password XXXXXXXXXXXXXXXXX
wlccp authentication-server infrastructure WLCCP
wlccp authentication-server client any WLCCP
ssid bigspace
wlccp wds priority 200 interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server attribute 32 include-in-accounting-req format %h
no radius-server attribute nas-port
radius-server host auth-port 2812 acct-port 2813 key XXXXXXXXXXXXX
radius-server retransmit 2
radius-server timeout 10
radius-server deadtime 3
radius-server vsa disallow unknown
radius-server vsa send accounting
radius-server vsa send authentication
Overall Rating: 5 (1 ratings)
Yosef Gunsburg Sun, 04/08/2012 - 21:56
I know this is late, but I think it can be helpful to those trying to send RADIUS accounting information.
I tried this out, and the reason this seems not to be sending the accounting information is because of the delay-start.
The delay-start does not seem to work with 802.11 connection accounting.
Yosef Gunsburg Sun, 04/08/2012 - 22:28
The delay-start option will wait until the NAS knows the client's IP address before sending an accounting request. This way, if the request should include the IP address it will be available.
For 802.11 the delay-start prevents the NAS from sending a request altogether.
Trending Topics - Security & Network
