VoIP on VLAN 1
Jaime Valencia Wed, 05/07/2008 - 11:13
  • Cisco Employee,
  • Hall of Fame,
    2011
vlan 1 is the default data vlan, if you configure a phone on a voice vlan then all the signaling will be on that vlan, not on vlan 1
javalenc
if this helps, please rate
gpulos Fri, 05/09/2008 - 07:20
  • Blue, 1500 points or more
No, cisco does not make any special use of vlan 1.
in fact, it is a general best practice to not use vlan 1 for any connections where possible.
(access and security reasons for the most part)
VoIP does not specifically use vlan1 for call signaling. VoIP will use whatever vlan your phone or CCM/CME is assigned to for call signaling.
It is best to create subinterfaces on your FastEthernet interface of the router to segregate your data and voice traffic. (or create SVIs on an L3 switch such as a 3560 w/EMI IOS)
Please see the following link for more info on voice vlans/configuration and and guidelines: (this is for an L3 switch, routers are slightly different; us the second link for router voice vlan config info)
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_37_se/configuration/guide/swvoip.html
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a00800ef797.shtml
