binding voice-port to specific timeslot
Answered Question
May 7th, 2008
Dear all,
I have a pbx and cisco 2821 with vwic.
i want to OPX on my router.
So on my pbx cas is configured with 30 specific number. on router side i have configured 30 seperate DS0 channel to achive 30 dedicated voice-port.
i have als0 30 FXS port on my router.
how can bind each fxs port into specific timeslot?
any idea?
Correct Answer by Paolo Bevilacqua about 8 years 8 months ago
Each fxs had a different plar string for a different timeslot. Any fxs is ok for that.
Overall Rating: 4.7 (3 ratings)
Paolo Bevilacqua Wed, 05/07/2008 - 11:50
Hi, you've asked this question already, which signaling type do your PBX uses ?
Eg, if E1 R2, is not necessary to assign each port to a timeslot.
miskoolak Wed, 05/07/2008 - 11:58
the signalling between pbx and router is fxo-loop-start.
i have provided the connection between pbx phone extension into fxs ports.
but the problem is when you dial-out from fxo phone into pbx every time one number is appeared on pbx phone extension.
it seems some kind of round robin between dso timeslot..but i need one fxs phone uses just one and specific ds0 timeslot for dial-out.
any way thank you for you follow up my friend.
Paolo Bevilacqua Wed, 05/07/2008 - 13:10
Ok. Remove the 'cas-group' under controller. Configure instead 30 times, cas-group number from 1 to 31 with the correct timeslot - remember you have to skip 16.
Configure 30 dial-peers, one for each of the new 30 voice-ports that are consequently created, with destinaion-patter like C01 ... C31.
Under the voice-ports for fxs, configure "connection trunk Cxx" with xx being number for the corresponding timeslot.
This way, as soon you lift phone, you will have dial-tone from PBX.
miskoolak Thu, 05/08/2008 - 00:36
HI dear bevilacqua ;
according to your idea I have to small mistake.
I have to define "Connection PLAR ####" for each logical voice port "voice-port 0/3/0:1"
to make pbx extention call into fxs phones..
---here my config------
controller e1 0/3/0
ds0-group 1 timeslot 1 type fxo-loop-start
ds0-group 1 timeslot 1 type fx0-loop-start
voce-port 0/3/0:1
connection plar 40001
voice-port0/3/0:2
connection plar 40002
voice-port 0/1/0
description fxs port
voice-port 0/1/1
dial-peer voice 40001 pots
port 0/1/0
destination-pattern 400001
dial-peer voice 40002 pots
port 0/1/1
dial-peer voice 41000 pots
port 0/3/0:1
forward-digit all
dial-peer voice 41001 pots
port 0/3/0:2
forward-digit all
note:
4100X are my pbx extension
behinde my pbx I have about 100 extensions
how can i dial all of them from my fxs phones??
note2:
calls from pbx to fxs are woking fine.
Paolo Bevilacqua Thu, 05/08/2008 - 02:17
under DP 41000 ... 41030 you need destination-pattern. I suggest to use Cxx, but you can use anything that is configured as connection plar under fxs port.
miskoolak Thu, 05/08/2008 - 03:01
please tell me how PBX dial tone will provided?
and what is your meaning with CXX?
Paolo Bevilacqua Thu, 05/08/2008 - 03:20
Once plar completes, fxo goes off hook and you have dialtone. Cxx are just numbers, you can use others.
miskoolak Thu, 05/08/2008 - 03:51
You mean that I should provide "connection plar XXXX" under my FXS voice-port?
that XXXX mentions to PBX phone extension number?
then how it understand to select proper dso timeslot..(To prevent worng caller id on pbx extension)
thank you again.
miskoolak Thu, 05/08/2008 - 03:52
teh other poitn is that is FXS-DID needed for this isuue or normal FXS can handel it?
Correct Answer
Paolo Bevilacqua Thu, 05/08/2008 - 04:00
