3548 Guest VLAN capability
Answered Question
May 7th, 2008
Does anyone know if the 3548 will support the guest vlan capabilities on the switch interfaces and if so, do you know which software version supports this.
Thanks.
Jeff
Correct Answer by Jagdeep Gambhir about 8 years 9 months ago
Jeff,
This feature is not supported on the XL switches.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Wed, 05/07/2008 - 12:04
Jeff,
~JG
jeff03038 Wed, 05/07/2008 - 12:16
JG,
Thanks very much for the information. I was able to do this on the 2950s with the latest release but I couldn't find any information on the 3845.
Thanks again.
Jeff
