CCM6.1 interconnect to another VoIP System
Brandon Buffin Wed, 05/07/2008 - 12:58
On the right hand side of the link in your post, there is a brochure that indicates that Telecenter can interoperate using H.323 or SIP. Assuming Telecenter implements these protocols in a standard way, you should be able to use a trunk from CCM without a problem. If you do a Google search for "Cisco Rauland", you'll see several examples of Cisco and Rauland working together in the healthcare field.
Hope this helps.
