Slow network speeds
May 7th, 2008
Just installed a 6509e and a 3560 switch in my LAN. Singlemode fiber is connecting the 2 switches using gbics. When moving data between the switches, transfer speeds get no higher than around 50mbps. Doing a sh int gig 5/1 produces the following. Lot of input errors. I would think possibly a duplex/speed mismatch, but it does not appear that I can configure on the sfp ports. Any help would be greatly appreciated.
GigabitEthernet5/1 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0016.4708.9d30 (bia 0016.4708.9d3
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 254/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is SX
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:01:18, output 00:00:45, output hang never
Last clearing of "show interface" counters 01:10:38
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 7000 bits/sec, 9 packets/sec
351983 packets input, 237817255 bytes, 0 no buffer
Received 123 broadcasts (91 multicasts)
158 runts, 0 giants, 0 throttles
830 input errors, 0 CRC, 672 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
415507 packets output, 438367084 bytes, 0 underruns
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 05/07/2008 - 15:07
  • Hall of Fame,
    Founding Member
Hi, you have some input errors, although not very many. You should look in having your fiber patch replaced.
vanguard1 Fri, 05/09/2008 - 12:02
I will have the fiber patch tested. Using ethernet backbone speeds were fine and no input errors. On the fiber port, after changing where I was plugged in on the panel, the times were better, but the input errors were still increasing. Link light was flashing green/orange indicating an error. Speeds were better, but would fluctuate.
donlerche Fri, 05/09/2008 - 10:54
You said you are using single mode fibre for the link, but the the show interface output states media type is SX - this indicates a multi mode transciever (If SFP/GBIC were single mode , then media type would be LX or LH). You cannot mix these modes unless using fibre mode conditioning patch leads. This may be your problem,
Hope this helps
Don
vanguard1 Mon, 05/12/2008 - 17:51
Thank you. Makes sense. I will check gbic tomorrow.
