TLS configuration with Frame-relay backup
May 7th, 2008
Brief about the network.
Core consist of 6509 where all the access vlans has been configured.
Access vlan ips - 10.0.0.0 range.
server vlan 172.21.0.0 as mentioned in dia.
Backbone router consist of 7200 series router where all the branch office at terminated through FR link.
EIGRP config has been mentioned in brief network diagram.
We hv got TLS service from verizon for three of our location i.e for core(100Mbps) and two of branch office(10Mbps).
I wanted to know as how can I configure the Branch office Vlan on Core and make the TLS as the primary link for two of our branch office without any major EIGRP routing changes. Also would like to use existing Frame-relay ckt at the branch as a backup to TLS ?
I highly appreciate for help.
Edison Ortiz Thu, 05/08/2008 - 16:59
  • Hall of Fame,
    Founding Member
EIGRP relies on bandwidth or delay as routing metric. If you want to select the TLS over the Frame-Relay link, modify the bandwidth statement on the Layer3 TLS connection to be higher than the Frame-Relay.
HTH,
__
Edison.
