IOS Webvpn HTTP 404
Answered Question
May 7th, 2008
I have a 2811 configured with thin-client Webvpn. When I launch the browser, after the certifticate is accepted, I get HTTP 404 error. Debug webvpn webservice says: Created HTTP reply for not found message.
It seems the file index.html cannot be found.
Any suggestions are appreciated.
Correct Answer by owillins about 9 years 2 weeks ago
Better you just remove the 'domain' option from the gateway command ie don't remove the whole 'gateway' command
Overall Rating: 5 (1 ratings)
Correct Answer
owillins Tue, 05/13/2008 - 08:05
  • Silver, 250 points or more
Chuan Liu Tue, 05/13/2008 - 12:25
Thanks. It starts working as soon as I remove the 'domain'.
