PPTP traffic cannot pass through pix 525 7.0(7)
May 7th, 2008
first:
i read cisco document:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094a5a.shtml#new
pptp client is in inside,
pptp server is in outside.
when i donot use firewall, the pptp connection can establish successfully.
but use pix 525 7.0(7)
i config:
inspect pptp.
pptp connection cannot setup.
show connection in pix:
pptp tcp 1723 is ok.
gre connection only one "E" flag, E means 'outside back connection'.
i try second method:
delete 'inspect pptp',
permit tcp 1723 and gre traffic from outside to inside, and i have config static nat,
but the pptp connection cannot work too.
so i think there is a pptp bug exist in pix 7.0(7).
can you help me about the question?
thanks a lot.
smahbub Tue, 05/13/2008 - 06:04
  • Silver, 250 points or more
You can only have one PPTP/L2TP connection through the PIX Security Appliance when you use PAT. This is because the necessary GRE connection is established over port 0 and the PIX Security Appliance only maps port 0 to one host.
refer the following url for pptp configration and troubleshooting on PIX
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080143a5d.shtml#tshoot
xh_liu Tue, 05/13/2008 - 16:44
i donot need config pptp client or server on pix,
i just want pptp traffic pass through pix firewall.
damoy Tue, 01/20/2009 - 12:54
I had the same issue. When I put in the inspect pptp command, I got the same results as you did. FWIW - I entered the old "fixup protocol pptp 1723" (which is just supposed to add the "inspect pptp", right?). Now all of a sudden it's working. Only difference is I'm running 8.03 code.
Rafael Trujilho Mon, 07/11/2011 - 07:04
I have the same environment of "xl_liu", follows information:
  • Firewall
    • Cisco PIX 525 - PIX/IOS v7.2(4)
  • Topology
    • CLIENT (INSIDE) |----------| PIX |----------| Server PPTP (OUTSIDE)
  • Configuration
    • Rules
      • access-list inside_access_in permit gre host host
      • access-list inside_access_in permit tcp host host eq 1723
      • access-group inside_access_in in interface INSIDE
    • Inspection
      • policy-map global_policy
                         class inspection_default
                           inspect pptp
The unique solution in case above is PIX/OS upgrade?
Thanks for colaboration!
