make outgoing calls
Answered Question
May 7th, 2008
i just setup correctly my voice gateway and the caal manager. Both device can communicate i think. Now i want to know what is the minimum configuration i have to complete in the CCM in order to make outgoing to PSTN call and receiving call from PSTN.
Materials :
CCM 4.1
voice gateway cisco 2801 with VWIC-2MFT-E1
Correct Answer by Jaime Valencia about 9 years 1 month ago
great news, for the incoming as i mentioned all you need to configure is the incoming CSS and the significant digits under the GW config
the CSS needs to reach the phones and the significant digits how many are you going to use
ie, if you receive 10 digits but you only use the last 4, set the significant digits to 4.
if you already receive 4 and have DIDs then there is really no need
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 05/07/2008 - 18:57
  • Cisco Employee,
  • Hall of Fame,
    2011
in first place configure the gateway using MGCP or H323
for outgoing configure a route group and add the GW
then create a route list and add the route group
create a route pattern and assign to it the route list
for incoming configure the significant digits and the incoming CSS to reach the phones
if H323 make sure you have the necessary dial-peers configured
you can go thru this doc for a better understanding
Call Routing in Cisco Unified CallManager
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/4x/42dialpl.html#wp1043613
javalenc
dom.a Thu, 05/08/2008 - 10:06
Thks for this document.
In your reply i cannot understand what you mean by "for incoming configure the significant digits and the incoming CSS to reach the phones".
Could you please be more explicit ?
I use a MGCP Gateway, so do you mean that all configuration about 'dial-peer voice' in the voice gateway are irrelevant ?
Jaime Valencia Thu, 05/08/2008 - 10:17
  • Cisco Employee,
  • Hall of Fame,
    2011
MGCP does not use voip dial-peers, go to the GW or endpoint config in CUCM and you will find those parameters
javalenc
dom.a Thu, 05/08/2008 - 12:37
I'm trying to configure a route group, but there is no device in the Available Devices list box.
The voice gateway is still well registered in the CCM. Is there something missing in gateway parameters ?
dom.a Thu, 05/08/2008 - 15:32
I have resolved the problem. A previous route pattern not well configured was using this gateway. I have sorted this out. Now i can make outgoing call. I'm trying now to configure incoming call.
Correct Answer
Jaime Valencia Thu, 05/08/2008 - 16:03
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
