CME 4.1 SIP Trunk and Call Forward
paolo bevilacqua Wed, 05/07/2008 - 17:20
  • Hall of Fame,
    Founding Member
Can you check with "debug ccsip message" and "term mon" if it the call is made and if so why it fails ?
paolo bevilacqua Thu, 05/08/2008 - 02:24
  • Hall of Fame,
    Founding Member
Hi, the call seem to be connected, do you see it connected or what else ? Do you have allow connections sip to sip in config ?
paolo bevilacqua Thu, 05/08/2008 - 06:06
  • Hall of Fame,
    Founding Member
Check what the calling phone show, according to the router the call is connected and you should see that with "show call voice active".
chadlincoln Thu, 05/08/2008 - 04:25
  • Bronze, 100 points or more
Are you getting fast busy? Just silence? Can you transfer manually at all? If you can transfer manually, you have to set up a translation pattern for the redirect. For a time, we could manually transfer to somebody's cell phone but couldn't call-forward all to a phone. Let me know if you can transfer to a PSTN number first then we'll go from there.
kgroves42 Thu, 05/08/2008 - 09:31
Not sure if this is your problem but, I just had this problem and it was an issue that we were sending the 4 digit extension as the Caller ID to the SIP trunk, which they did not like. So I had to add a translation rule to make it the main number
voice translation-rule 6
rule 1 /.*/ /14155551212/
voice translation-rule 5
rule 1 /^8/ //
voice translation-profile CID
translate called 5
translate redirect-called 6
then add that rule to my dial-peer
dial-peer voice 110 voip
description voip dial peer to Verizon
translation-profile outgoing CID
destination-pattern 8T
modem passthrough nse codec g711ulaw
voice-class codec 1
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte digit-drop
fax-relay ecm disable
fax rate disable
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
i have a CLID network-number command on the outgoing dial=peer to mask the extention number to the SIP trunk, that works great. Now i just need the CME system to use our mail number to call-forward/call-tranfer to the outside, because that is the only number our provider will accept a call from.
I think i need to use the "call-number local" command but I am unsure.
paolo bevilacqua Thu, 05/08/2008 - 09:45
  • Hall of Fame,
    Founding Member
That is quite possible, however the thing is that from the trace you sent, the forwarded call is accepted and connected.
We could check that are the media addresses, perhaps do expect that media is sent to you then sent back.
