How to communicate between CRS and an external web server
May 7th, 2008
Hello -
I am working on a typical banking application. I need to collect
information like
[Account]
Please enter your 16-digit account number now.
Please enter your 4 digit pass code now.
[Passcode]
which is not a problem.
And then have to send this to a host - post using XML document and get a
response back.
Should I use the Create URL document with the above 2 parameters
collected from the caller?
How do I send the document to a web service and get information like
account balance etc.?
Could you recommend some sample steps? My application script will be
handling the call contact trigger.
Thanks.
Document Step Types 2-239
Cache Document Step 2-240
Create File Document Step 2-243
Create URL Document Step 2-245
Create XML Document Step 2-248
Get XML Document Data Step 2-250
Keyword Transform Document Step 2-253
Upload Document Step 2-256
Write Document Step 2-258
XSL Transform Document Step 2-259
HTTP Contact Steps 2-89
Get Http Contact Info Step 2-90
General tab (Get Http Contact Info step) 2-92
Headers tab (Get Http Contact Info step) 2-93
Parameters tab (Get Http Contact Info step) 2-96
Cookies tab (Get Http Contact Info step) 2-98
CGI Variables tab (Get Http Contact Info step) 2-100
Http Forward Step 2-103
Http Include Step 2-107
Http Redirect Step 2-110
Send Http Response Step 2-111
Set Http Contact Info Step 2-113
General tab (Set Http Contact step) 2-114
Headers tab (Set Http Contact step) 2-115
Cookies tab (Set Http Contact step) 2-116
Overall Rating: 3 (1 ratings)
smalkeric Tue, 05/13/2008 - 13:19
on CTI, create a custom ActiveX COM object to enable IVR to receive timeout if backend database application or web services goes down.
