Router Restart reason??
May 7th, 2008
Hi there. i wonder if my router restarted due to reload command or by error because the system restarted and the returned to rom time is differ. here is the capture:
<Router> uptime is 16 hours, 43 minutes
System returned to ROM by reload at 14:13:51 GMT Mon Aug 23 2004
System restarted at 17:05:01 WIB Wed May 7 2008
System image file is "slot0:rsp-pv-mz.120-11.S3".
tx anyway..
Pravin Phadte Thu, 05/08/2008 - 05:32
  • Silver, 250 points or more
Seems to me like it by reload.
There are chances that the registery value been changed and router reloaded.
If there is any software error you will able to see it in dir flash command or show flash.
this command will show u the router crashinfo
