Re: To check IP with high utilization on an interface ...
Answered Question
May 7th, 2008
I would like to know if there is high traffic on an interface ie) serial inteface, what is the
command to check which is the top talker/ relevant IP that is causing this high utilization on this inteface ?
Thank you,
Cheers,
- sn -
Correct Answer by alessandro.veras about 8 years 8 months ago
If you don't have a netflow analyzer server you can use the ip route-cache flow command.
Configure the ip route-cache flow at the specific interface.
Issue the show ip cache flow command.
To see statiscs by protocol ( do not show the ip address ) configure the command ip nbar protocol-discovery on the selected interface and issue de command sh ip nbar protocol-discovery top-n;
Hope can help.
Please rate the answer.
Overall Rating: 5 (5 ratings)
faisal_ghaus Wed, 05/07/2008 - 23:44
The better solution for this is Netflow but simple work around is enable
ip accounting command on the interface you will get the top talkers
Correct Answer
alessandro.veras Thu, 05/08/2008 - 00:21
Hope can help.
