IP Communicator : using the Audio IP Address
May 8th, 2008
How to use the Audio IP Adress in the IP Communicator.(Preference->Audio->Network->Audio IP Address)
I use a switch where i've declared the Voice VLAN and the VLAN access(for data).
And I want to use the VLAN Voice for my IP Communicator.
And whe I call, the phone ring, i can accept the call but there is no sound.
How to fix it?
Thank you
Jaime Valencia Thu, 05/08/2008 - 11:19
  • Cisco Employee,
  • Hall of Fame,
    2011
do you have all the proper routing configured so the RTP reaches that IP??
If you leave the ip just as is, does it work?
javalenc
if this helps, please rate
connect101 Thu, 05/08/2008 - 23:48
I don't understand : do you have all the proper routing configured so the RTP reaches that IP??
In the router, i've already configured all routing information.
If i leave the ip just as is with the data, it works.
