PIX525 and IE
Answered Question
May 8th, 2008
Hi all,
How can i make PIX525 working through IE, Which program that should be added to PIX525 that make it working through IE?
best regards
thaar
Correct Answer by smahbub about 9 years 1 month ago
To use ASDM, you need to enable the HTTPS server, and allow HTTPS connections to the security appliance. All of these tasks are completed if you use the setup command.The security appliance allows a maximum of 5 concurrent ASDM instances per context, if available, with a maximum of 32 ASDM instances between all contexts. WebVPN and ASDM administration cannot be enabled on the same interface. If you enable WebVPN on an interface, then that interface cannot be used for ASDM.
Uset the below commands for configuring ADSM:
hostname(config)# http source_IP_address mask source_interface
hostname(config)# http server enable
hostname(config)# asdm image disk0:/asdmfile
Refer the following url for more info:
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/mgaccess.html#wp1047288
Overall Rating: 5 (1 ratings)
Correct Answer
smahbub Wed, 05/14/2008 - 06:08
  • Silver, 250 points or more
