Incoming caller ID
May 8th, 2008
Hi Probably a really stupid question but....
I have CME everything is working fine however all incoming calls are showing up as unknown number. I have searched on google but all I could find was to use the caller-id enable command on the voice ports however the CME 4.2 I am using will not allow me to use this command, it just doesn't list it in the options. Any help would be great.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Thu, 05/08/2008 - 02:38
  • Hall of Fame,
    Founding Member
Do you have fxo lines? It doesn't "take it" under there ?
paolo bevilacqua Thu, 05/08/2008 - 02:43
  • Hall of Fame,
    Founding Member
You should check "debug isdn q931" with "term mon" for an incoming call. check if the calling number is in there. If is not, complain to telco.
scottwclarke Thu, 05/08/2008 - 02:54
Output of debug on a call....
May 8 10:52:12.987: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8483 - Origination address is non-ISDN
Called Party Number i = 0x81, '200000'
Plan:ISDN, Type:Unknown
May 8 10:52:13.015: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
May 8 10:52:13.063: ISDN BR0/1/1 Q931: TX -> ALERTING pd = 8 callref = 0x81
Progress Ind i = 0x8188 - In-band info or appropriate now available
May 8 10:52:18.711: ISDN BR0/1/1 Q931: TX -> CONNECT pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
May 8 10:52:18.767: ISDN BR0/1/1 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
May 8 10:52:18.767: %ISDN-6-CONNECT: Interface BRI0/1/1:1 is now connected to N/A N/A
May 8 10:52:25.698: %ISDN-6-DISCONNECT: Interface BRI0/1/1:1 disconnected from unknown , call lasted 6 seconds
May 8 10:52:25.698: ISDN BR0/1/1 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x8090 - Normal call clearing
May 8 10:52:25.834: ISDN BR0/1/1 Q931: RX <- RELEASE pd = 8 callref = 0x01
May 8 10:52:25.838: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
I can't see the incoming do you think this is the telco
paolo bevilacqua Thu, 05/08/2008 - 03:21
  • Hall of Fame,
    Founding Member
Correct, telco is not sending calling number.
joel.balfour Thu, 05/08/2008 - 05:43
Hello;
basically you need to check few things here and this will determine your answer:
1. The FXO port that you have is it one that support caller-id functionality like the vic2-fxo-m1 or m2 modules.
2. Make sure your provider is sending out the caller ID on their end.
If these 2 are ok then you should not have a problem but you can do the following under the fx0 port (caller-id enable).
JRB
paolo bevilacqua Thu, 05/08/2008 - 05:45
  • Hall of Fame,
    Founding Member
He doesn't have fxo. He does have isdn bri.
