Question about Wireless Controller and LAG.
rcapao
I have a Wireless Controller 4400.
When I configure the controller with LAG, I have to connect the controller to a L3 switch?
If I connect the controller to a L2 switch the LAG works?
Some one can tell me something about this?
Thanks in advance,
Rui
18 Replies 18
ericgarnel
Level 7
Level 7
It doesn't matter if the switch is l2 or l3, the etherchannel port & physical port members of the etherchannel port on the switch will need to be in layer 2 802.1q trunking mode
check out http://www.cisco.com/en/US/tech/tk389/tk213/tsd_technology_support_protocol_home.html
That's OK. I agree with you. I think that's correct thinking like that.
But I did what Cisco says about configuring Etherchannel between a switch 2960 and a wireless controller… and what I have is this:
bastack3#sh lacp 1 internal det
Channel group 1 is not participating in LACP
bastack3#
bastack3#
bastack3#
and in the switch I have:
interface Port-channel1
switchport trunk allowed vlan 8,9,99
switchport mode trunk
interface GigabitEthernet0/21
channel-group 1 mode on
interface GigabitEthernet0/22
I have too:
port-channel load-balance src-dst-ip
But nothing seems to be working.
Do you know why? There is something missing?
Can any one help me?
Thanks in advance,
Rui
Have you tried using pagp instead of lacp?
Also, what if you used auto instead of on?
I do not run lag on my 4402 controllers, as it was not up to snuff early on (3.x per TAC) and I can achieve the same with mulitple ap-management interfaces and differing port priority.
I will be replacing the 4402 units with wism blades soon, so all that will change a bit
I tried to config PagP, but don't worked.
If I tried with auto I will being configuring in PagP, and I which to configure LACP.
If you will have a WiSM it as LAG enabled by default…
Can you help me?
Can some one help me?
Rui
What 2960 model and what image is on it?
Also, how are you connecting the 4402 to the 2960, copper or fiber?
Connecting by cooper and the IOS is: c2960-lanbase-mz.122-35.SE5.bin.
Rui
Copper? so you are using rj-45 Gb SFPs on the controller. If that is the case, what is the speed of the switchports on the 2960?
I use the rj-45 Gb SFPs on our 4402s and they work fine connected to Gb rj-45 ports on the switches.
Also, check out the following:
http://www.cisco.com/en/US/docs/wireless/controller/4.2/configuration/guide/c42mint.html#wp1116136
"Using the CLI to Verify Link Aggregation Settings
To verify your LAG settings, enter this command:
show lag summary
Information similar to the following appears:
LAG Enabled
Configuring Neighbor Devices to Support LAG
The controller's neighbor devices must also be properly configured to support LAG.
•Each neighbor port to which the controller is connected should be configured as follows:
switchport
channel-group mode on
no shutdown
•The port channel on the neighbor switch should be configured as follows:
interface port-channel
switchport
switchport trunk native vlan
no shutdown
You have to set channel-group to 'on'. LAG will not work with lacp or pagp. When set to on, you aren't using any negotiation. Also the etherchannel load balancing has to be scr-dst-ip.
http://www.cisco.com/warp/public/102/wlc-config-best-practice.pdf
-Scott
I have a sw2960G.
The controller is connected with the switch by cooper in 2 interfaces in 1Gb.
The 2960 as 4 interfaces that could be connected by cooper or fibber, it depend what you need.
The configuration that I did put in the switch is:
I did this a couple days ago.
But that don't worked the LAG is not negotiated between the switch and the Controller.
Reading all the documentation that Cisco as for LAG, Cisco says it work… but in reality it don't work.
Can you help me?
Rui Capao
Post the sow run-config from the WLC cli and also post the show etherchannel on the switch.
-Scott
OK!
I was looking for the show run-config not the show running-config.
But looking at the sw2960_1, it looks like you do have etherchannel running on both ports.
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SU) - Gi0/21(P) Gi0/22(P)
Po1(SU) means Port Channel 1 is in layer 2 and in use
Gi0/21 (P) & Gi0/22 (P) shows that both ports are in port channel.
-Scott
Yes saw that, but the problem is that LACP is not working, I mean, the load balancing is not working…
When a unplug one of the cables in the WLC. The connectivity between the switch and the WLC stops.
That is the problem…
There is something that I have to do?
There is something I forgot?
Rui
Well for one, when channel mode is set to on, it doesn't use either lacp or pagp. you can configure udld on the switch and see if that helps. Even when a wlc fails, its not a clean failover. the ap's will reboot and have to join the other wlc.
-Scott
