ASA Active/Standby ASDM Configuration Problem
May 8th, 2008
I am trying to configure Active/Standby LAN-based stateful failover on two ASA 5510 running OS version 7.2(3)and having Security Plus license.
I assigned IP addresses to the interfaces as shown in the attachement and I could ping all interfaces. The interfaces are connected using cross-over cables.
When I started High Availability Wizard in ASDM to configure Failover, I get the error message " One or more of the peer connectivity or cpmpatibility test failed. You must resolve the problems before you can proceed further."
Also, I tried configuring failover using the CLI according to the document at http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/failover.html#wpmkr1133737.
When I got to step 4b under LAN based failover, I get the error message:
Primary-ASA(config)# failover interface ip failover 192.168.200.1 255.255.255.252 standby 192.168.200.2
Interface failover is not a failover or stateful interface.
Any ideas on what I am doing wrong? Any problems with licensing on these ASAs?
Thanks for your help.
a.ajiboye Thu, 05/08/2008 - 07:53
Thanks. I solved the problem.
It was due to the old config that I had on the ASAs. I simply removed the old config and started afresh.
