dynamips help
Answered Question
May 8th, 2008
is any body suggest me, what router ios will support for switching like rstp stp n glbp. to use in dynamips emulator
Correct Answer by Edison Ortiz about 8 years 11 months ago
In my CCNP days, there was no such thing as dynamips so I can't really offer much guidance as to the extend of help this product can provide.
However, I must say, it should help you around 80% to 85% of the general task. The 15% to 20% is mostly due to switching but you should be able to perform 100% of routing tasks.
For switching task which you can't do in dynamips, I recommend renting a rack for a day or two. They are quite cheap. Just google for 'CCIE Rental Racks'.
HTH,
__
Edison.
My Dynamips:
Rack1SW1#sh ver | i IOS
Cisco IOS Software, 3600 Software (C3640-IK9S-M), Version 12.4(17), RELEASE SOFTWARE (fc1)
Rack1SW1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Rack1SW1(config)#spanning-tree ?
backbonefast Enable BackboneFast Feature
portfast Spanning tree portfast options
uplinkfast Enable UplinkFast Feature
vlan VLAN Switch Spanning Tree
As you see, I have uplinkfast and backbonefast available.
Can I change the mode to RSTP? No.
But I have the features available that makes up RSTP.
BTW, you are only available to run CST (Common Spanning Tree) on Dynamips not PVST nor RPVST.
HTH,
__
Edison.
Overall Rating: 5 (2 ratings)
Collin Clark Thu, 05/08/2008 - 08:38
  • Purple, 4500 points or more
None, it does not emulate switches.
mohanreddy.madan Fri, 05/09/2008 - 02:07
i know dynamips will not emulate switches but when we include 16 port eth. card it will, now i want 2 know witch ios (router) will support max commands of switching lab i.e. 3550,3560 switch commands.i think u hav an idea which searis of routers dynamips supports,becoz i want to practice ccnp bcmsn lab on dynamips.ok
thank u for ur reply
mohanreddy.madan Sun, 05/11/2008 - 02:09
thank u pravin,
i know that forum i already checked it but unfortunatly i did not get 100 % result..
any how thank u once again plz keep in touch
madan
Correct Answer
Edison Ortiz Sun, 05/11/2008 - 09:30
  • Hall of Fame,
    Founding Member
My Dynamips:
Rack1SW1#conf t
HTH,
__
Edison.
mohanreddy.madan Sun, 05/11/2008 - 23:30
hai Edison,
thank u very much 4 ur reply.1 more ?.for my ccnp preparation how much dynamips will help me.am i able to run r test all the labs whitch is in ccnp i.e. bsci, bcmsn,iscw and ont.
thank u
madan
Correct Answer
Edison Ortiz Mon, 05/12/2008 - 04:56
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
