Rajesh Revuru Thu, 05/08/2008 - 07:46
  • Silver, 250 points or more
I think you can as long as you are using MGCP for gateway protocol. I think it will generate alert lije CCMRegisteredGateways count was decreased by 1.
webstd.design Fri, 05/09/2008 - 07:22
Yes, but this alert notifies when CCM registration on CALLMANAGER goes down, not contr e1. I want to monitor controller e1 - like sh contr e1, and not sh ccm
Zin.Karzazi Fri, 05/09/2008 - 08:22
Try PRISpansInService, it indicates the Number of E1 Pri on both Gateways that are in Service. Alerts will be triggered if the value is under (number of E1 you have), which means one of your E1 is down.
