Different MCS Platform in the same UCM cluster?
Answered Question
May 8th, 2008
  • Gold, 750 points or more
I wanted to understand if I can have a UCM cluster with different MCS platforms.
For example MCS 7845 as a Publisher and MCS 7835 & MCS 7825 as a Subscriber.
I feel that technically this should be possible apart from considering the fallback capacity in case of the MCS failure. However I am interested to know if this is technically a feasible option or not.
Has anyone seen or done any such deployments.
Any inputs would be appreciable.
-> Sushil
Correct Answer by Rob Huffman about 8 years 11 months ago
Hi Sishil,
Hope all is well :) There is no requirement that all MCS Servers in a cluster be the exact same models. So, your example would work just fine as long, as you correctly noted, that "Failover" numbers are considered and factored into the equation.
Our MCS boxes are all the same right now but our past deployment had some differences that never caused any issues.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 05/08/2008 - 04:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Sishil,
Hope this helps!
Rob
Rob Huffman Fri, 05/09/2008 - 04:44
  • Hall of Fame,
    Founding Member
Hi Sushil,
You are most welcome my friend! Sorry for the delay in getting back to you :)
Take care,
Rob
Sushil Kumar Katre Fri, 05/09/2008 - 04:51
No problems Rob.I guess your reply was quick for me :)
-> Sushil
