Version 8.3
May 8th, 2008
Hi, We have multiple ASA's (7.2) and installed on different locations and we have established VPN connection among all of them. Now we want to upgrade 8.3 version one by one on all location. After upgrading it is required new configuration or all configuration will be remaining same and can VPN tuneel support between installed asa 5505 both have different versions (7.2 and 8.3). Please tell us the advantage of version 8.3 as well. Thanks..
smahbub Wed, 05/14/2008 - 11:20
  • Silver, 250 points or more
Take a backup of the existing configuration on all the ASA'S.Check for the commands available in the version 7.2 na d its equivalent command in 8.3.The commands may get upgraded to 8.0 automatically.few commands may have to be entered maually in different modes.
Refer the following url for ASA command guide:
version 7.2--http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/crt_72.pdf
version 8.1--http://www.cisco.com/en/US/docs/security/asa/asa81/command/ref/cmdref81.pdf
CSCO10106129 Thu, 05/22/2008 - 08:42
apologies to original poster as this may take this discussion of track. However, is it advisable to upgrade to version 8.*.* from 7.*.*
