Router Interface down
Pravin Phadte Thu, 05/08/2008 - 07:59
Yes try as above mentioed.
Set full duplex on the router interface and the switch interface.
Still if it does not come up set both to auto and check.
setting it to auto will auto neigo the speed check in which speed it is up. half or full.
if still in half i would suggest to change the cable might help.
Pravin Phadte Fri, 05/09/2008 - 06:57
Below command will help
config t
int fa0/20
(config-if)#dup
(config-if)#duplex ?
auto Enable AUTO duplex configuration
full Force full duplex operation
half Force half-duplex operation
