How to build a string from user input. Please Help
May 8th, 2008
I am dynamically creating CiscoIPPhone menus from database entries. From each one of these menu objects, the user makes a selection. Is it possible to concatenate all the users' selections into one string to send back to the server?
Thanks For Your Time,
Michael
agiaccone Thu, 05/08/2008 - 07:38
  • Bronze, 100 points or more
Hi Michael,
the best way to accomplish this ,IMHO, is to create a CiscoIPPhoneMenu page the calls itself at each selection, adding serverside the value prevoiusly selected.
Something like this :
http://testserver/menu.aspx
Title
Prompt
Select 1
QueryStringParam:sel=Select1
Select 2
QueryStringParam:sel=Select2
User select "Select 2"...
http://testserver/menu.aspx?sel=select2
Title
Prompt
Select 3
QueryStringParam:sel2=Select3
Select 4
QueryStringParam:sel2=Select4
and so on...
look here for reference :
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/all_models/xsi/5_0_2/english/programming/guide/ip502ch3.html#wp1033185
HTH,
Alberto
if it helped please rate
