shell command authorization set
May 8th, 2008
umatched commands set to deny
command "configure" argument "permit terminal"
user has full access to all. i just want user to adjust vty lines. I also have the following commands
show with argument"permit run and start"
thats all i have set up in command. they should not be able to do anything in the config mode "Yet"
james-benson Thu, 05/08/2008 - 07:24
I actually set up the commands using that document. it is supposed to deny anything else once you are in the config mode. because i have no other commands or arguments defined. but i have full control
james-benson Thu, 05/08/2008 - 08:38
i do not have that in my config. I do not know where i would put it. here is my config
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication login no_tacacs enable
aaa authentication enable default group tacacs+ enable
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa authorization network default group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
Jagdeep Gambhir Thu, 05/08/2008 - 08:42
You need issue that command in config t mode
aaa authorization config-command
That will take care of your issue.
~JG
Do rate helpful posts
jong_r0602 Thu, 05/08/2008 - 07:54
Hi James,
Is there a privilege level defined on your vty? Especially if theres a privilege level is 15, remove it first then try it again.
Jong
jong_r0602 Thu, 05/08/2008 - 19:19
ok, all you have to do is to follow JG's instruction above on his previous mail to enter the "aaa authorization config-command" in config t mode.
Jong
