md5sum utility
May 8th, 2008
I was reading the CM 6.1.2 Release notes and there is a step below-
Step 3 Use an md5sum utility to verify that the MD5 sum of the final file is correct.
Does anyone have a suggestion on a particular utility that they have used.
jarmitage Thu, 05/08/2008 - 09:12
Hi Shane,
If you're using linux, you probably have md5sum already. Go to your command line and type either "which md5sum" or "man md5sum".
On windows, the popular choice is "md5sum.exe"
The .exe:
http://etree.org/cgi-bin/counter.cgi/software/md5sum.exe
Usage example, linux & windows:
http://linux.byexamples.com/archives/198/md5-checksum-how-to/
Usage example, windows only:
http://etree.org/md5com.html
Hope that helps!
-James.
